BIKE VAULT is a safe and secure bike storage solution.
BIKE VAULT comes in two variants: Original, designed for one bike, and Extra designed for two bikes or one large bike (29er MTB, Enduro, Dutch, eBike).
BIKE VAULT is manufactured from super tough recyclable low density polyethylene. The LDPE is UV treated and will not deteriorate or discolour over time. LDPE is also very unreactive and resistant to graffiti!
BIKE VAULT bodies are manufactured from 100% recycled LDPE. This is reprocessed scrap material and is physically identical to new LDPE and are black. Also available for doors.
BIKE VAULT features double security. The door hasps are made of protected stainless steel tabs, drilled to accept padlocks. Internally it is designed so that a ground anchor can be installed to accept a D Lock or chain for additional security.
BIKE VAULT is weatherproof so your bike is kept clean and dry and there's space to store your helmet and other bike kit safely with your bike.
BIKE VAULT's attractive design means it will look good anywhere. At the front of your property (or any other location you would like to see one!) where it is most convenient for storing your bike. No need to carry your (possibly muddy and wet) bike round, or worse still, through your house.
Leave all your bike essentials with your bike.
BIKE VAULT is manufactured simply as a body and door and is supplied fully assembled and complete.
Bike Vault Original Tech Spec Bike Vault Extra Tech Spec
Absolutely no assembly required.
Each BIKE VAULT is delivered with Rawl Bolt base fixings, tapered door knob and instructions for installation.
Only basic DIY skills and DIY tools are required for installation.
BIKE VAULT's standard from stock colour is a black body and light blue door.
Other standard colours are all of those at the top as well as dark green, yellow and black. Other colours available on request.
For maximum security for your cycle buy a Bike Vault and our secure accessories!
Commercial Contractor Aspects:
Delivered palletised and fully assembled
At contractor level incredibly fast and easy installation
Being recycled and recyclable Bike Vault has excellent for sustainability credentials
Flexible layout options for condensed high volume installations
Lead time from purchase order to delivery 10-15 working days
View Bike Vault Original's Car Parking & Circular Layout's (PDF: 325Kb opens in new tab)
BIKE VAULT shop Now.. www.soldsecure.net
